Ready for 6 months of Winter
Just got some jack stands under our T@G's frame lifted up just enough to take the load off of the tires. The tires aren't quite off the ground. By December, we'll probably be unable to get into the shelter, so, it's goodnight to our Poppi until probably late April.
Or you could just put some chalk marks on the tires and move the trailer a little every month or so
If you knew our winters, the deep snow will keep us from entering our shelter for at least December to April. Actually, today we decided to build a short front and back wall and run 2 14 ft supports underneath where the top ribs connect, just for extra support during those fierce snowfalls where we just can't keep up.
Be careful where you put the jack stands. I know on the TaB, if you put it on the axle it can damage it.
