2021 TAG Boondock rear stabalizer jacks
Found out the hard way that you need to tie the rear jacks up... They came down while crossing the desert and one tore off and the other bent beyond use.... Anyone know of a good replacement jack? Not going to replace them with the cheap factory ones...
I'm sure you can find good replacements on eTrailer.com
Thanks, already looking on eTrailer... Lots of choices... Was hoping someone on this forum might have already found a pair that works good...
@JDW, sorry to hear that your stabilizer jacks got damaged.
Mine have never moved while traveling. That includes many miles of rough dirt roads and bumpy highways
I do make sure they are cranked up all the way and that the pads are level with the ground.
I've torn a pair off by forgetting to raise them. That's when I started using a checklist. Only plan to do it once...
