Rhino tote tank
arubino
Member Posts: 16
anybody have any resourceful ideas for attaching the rhino tote tank to the tag? thinking about using camco's kit to attach and drilling a couple bolt holes with a metal plate into the trailer frame between the U-bolt to fasten it to the trailer...hang it where the cowbell exhaust is near the back of the trailer.
Not sure if I would put a full tank (120lbs extra weight) at that point behind the axel without compensating for the weight somewhere in font of the axel to keep tongue weight the same as prior to the mod.
yes, thanks, I was referring to it being empty. I will dump it at site.
@arubino - do a search here on Rotopax. Several members have installed them on the sides of the TaG.
