What works connected to 20amp?
We have a 2022 Tag. I’m guessing the heat and AC won’t work when connected to 20amp. Will the microwave work?
    JamesDow Member Posts: 754
    edited June 2024
    Everything will work powered with 20 amp. 20A x 120V = 2,400 watts.
  • The_Rigger
    The_Rigger Member Posts: 204
    edited June 2024
    I'm assuming you're talking about AC power, rather than DC (the battery). All the AC appliances should work; they just may not all work at peak capacity at the same time. The trailer would really rather see 30A.
  • hooksnatcher
    hooksnatcher Member Posts: 16
    edited June 2024
    I've run our 2017 T@G on 20 amp many times. No microwave, but with AC running and small K-cup coffee maker used frequently. I do use a heavy duty power cord to connect to the shore power. It's much less of a hassle to deal with over the 30 amp cord. The only time I've had trouble was with a wimpy GFI breaker on a shore power box one time.
