HikinMike
Member Posts: 400
Although the white plastic faucet does the job; I would like a chrome, nickel or stainless steel looking faucet. Has anyone done that? If yes, which faucet did you select?
It is a 12V faucet and there doesnt appear to be many chrome/nickel replacements. And to show you how much I use it, I just discovered its a 360 swivel faucet. I guess I'll keep it.
love the swivel part...while travelling I raise it and add some pipe insulation around it to protect it...we travel with a loaded galley and an outdoor rug on the counter...pipe insulation also protects the pex piping under the sink and the drain control
Nope, it is a standard type faucet for campers and sailboat. The pump as its on pressure switch on and off. Proof of that, look under tge counter, no electrical line, and is also work when you turn the side water line on, that as a standard water hose outlet.
It might be a little late, but I found a faucet that someone else had used on the facebook Tag group.
Decdeal Foldable RV Fauce
you will also need to get a 1/2" Female NPT to 3/8" Barb adapter, and a 1/2" FIP locknut (I found both at Ace Hardware for $10)
No, you aren't late. I like that faucet. A high rise like that would be nice.
