Hatch light is shorting out
blackc2004
After the last trip my hatch light is shorting out. It will go on and off randomly if you jiggle the cable between the hatch and the teardrop. I want to remove the light and see if it's just a loose wire but can't seem to figure out how to do that. Anyone have instructions on how to remove the light in the hatch?
Yeah thats another item configuration that makes no sense.
Try rotating the ring to the left. That works on the TaBs clamshell galley dome light.
@Sharon_is_SAM said:
Try rotating the ring to the left. That works on the TaBs clamshell galley dome light.Thanks. I used a flathead and just pried it off. I couldn't get it to rotate.
