Help using the external shower in in T@G XL 6-Wide Teardrop
Maxtab
Maxtab Member Posts: 3
I have tried following the instructions given by one of you on the discussions but I cannot figure it out.
In the video, I showed what I supposed to do. Please let me know if what I am doing wrong. Thanks
https://www.youtube.com/watch?v=uK2ZqEwzxCI
  • beaky
    beaky Member Posts: 283
    you have to plug in the hose, then turn on the pump
  • Fourman110
    Fourman110 Member Posts: 230
    The hose connector on mine was really stiff. Ou need to either pull or push the collar (mine is parked elsewhere and I can’t check) then really push straight onto the other side of the connector. Once it gives and seats, then release the collar. After hose is installed, pump on and go.
    Don’t forget to winterize the hose and spigot. Camco winterizing kit makes it a snap, keeping antifreeze out of the tank.
    I found on mine that if you turn off the pump, then release the system pressure by opening the sink spigot it's much easier to get the quick disconnect to seat. With pressure on the system, it was nearly impossible to connect the hose disconnect.
  • Maxtab
    I found the issue. I didn't open the silver nozzle. I was afraid of twist it with a wrench in case I would crack the pipe. But it worked.
