Where can I find sheets that fit?
Hi everyone just bought a 2020 T@G 5 wide and I can’t find any sheets that fit anywhere. Anyone have any suggestions?
2020 T@G Boondock Edge 5 wide
    JamesDow Member Posts: 751
    It is not easy to find sheets that will fit perfectly.
    Below is what I got from Amazon.
    No problems at all with the extra depth, they work just fine.
  • Donkeythekidd
    Donkeythekidd Member Posts: 40
    I found a couple places that make custom sizes but they are expensive.
    I ended up just going with a (full size) sheet set and mattress protector. I had a set on the guest bed so I checked how it fit. It was a little tight but you can't tell. I also went with the full set instead of trying to look for or spend a fortune on a custom one because I also had a spare memory foam mattress topper that wasn't being used I threw in the camper. It's also still easy to lift up either side to get to stuff underneath.
  • poliver
    poliver Member Posts: 33
    Call Kathie at Waterloo Mattress in Waterloo, Ontario. They are super helpful, priced right and can ship anywhere.
  • HikinMike
    HikinMike Member Posts: 400
    In my 5 wide, I have my mattresses on top of two REI Camp Bed 3.5 inflatable sleeping pads. Its a perfect fit inside the cabin. Using two pads allows my wife and I to control the firmness individually. I use full size sheets and they fit fairly well. I also use bed sheet elastic holder straps (Amazon) to help hold the corners of the fitted sheet in place.
  • Frogger
    Frogger Member Posts: 156
    @HikinMike like the idea of the self inflatable pads, may try those in time...
  • ontheroad
    ontheroad Member Posts: 190
    Sheet straps really work..we have the XL and use twin fitted sheets...
    2018 Nissan Pathfinder
