Galley Hinge
Does anyone know what the fabric is and where to find for the galley hinge on a 2017 T@B? Mine is fine but I am rehabbing another teardrop and thinking this would like to use one on galley hinge.
Thank you,
Dan
  • HikinMike
    HikinMike Member Posts: 400
    I dont have any fabric in my galley area.
    edited December 2020
    Email info@nucamprv.com. Just ask what kind of material was used for the TaB galley hinge. It seems to be a flexible, plastic of ripstop nylon.
  • danp
    danp Member Posts: 51
    I sent the email, thank you. It's on the outside and appears to be a cover for the galley hinge
    ine is a 2017, may not be on all.
    You could also call the factory and ask to speak to Austin Jones in the repair shop as he will be able to give you the info you need.
    It is a fiber reinforced Vinyl, almost the same type that is used for circus tents or party tents that you can rent.
  • Gerald98053
    Gerald98053 Member Posts: 25
    I have the 2017 TAG. The factory’s advice was not so helpful. “Take it to a dealer.” That was all they could tell me. I have a very tiny aging crack in the vinyl and I’ve patched it for now using buytl rubber.
    Gerald
    Redmond, Washington
    Nissan Armada
