wattage/amps for ac
anybody know the startup and run amps /watts for the haier ac in the 2020 tag?
    JamesDow Member Posts: 751
    The amps should be shown on the AC. Mine is on the side. Somewhat hard to read. Mine (not haier) was 4.0a
    This should be the max amp draw (running)
  • DCN082162
    DCN082162 Member Posts: 34
    The previous owner of my 2007 T@G said he measured starting draw of about 800 amps. Our Champion 2000 watt generator handles it fine.
  • DCN082162
    800 Watts, my mistake.
  • ras
    ras Member Posts: 213
    edited June 2021
    A lot of people don't realize that, if you click on the little wheel in the upper right hand corner of your finished post, you can edit your post. I did a lot of technical writing and I'm a little OCD. It usually takes me at least one edit to be satisfied with my post (as i just did)
  • DCN082162
    I did not know that thanks. I did poke around for an edit button but found nothing. Im similar to you I did a lot of technical writing as well. I almost never get it right the first time. In my offtime I have dabbled with writing short stories, fiction mostly. It's a different world.
