Roof fan not working
2021 TAG Boondock. have been many times already into the middle of nowhere of the Sierras. Absolutely the best times...
Fan does not come on. Just started last trip...
All other components working. Radio.water pump.led lights.etc. Have pulled all fuses. tripped breakers. roof fan bullet fuse is fine...
I'm at a loss......
Thanks in advance
2021 Tag Boondock
2021. I would guess it is still under manufactur warranty. My Fantastic Fan 2018 T@G made too much noise in low (my opinion) and they sent me one out at no cost in late 2019. My fan was easy to access and remove/replace.
Just a thought.
@ididntknowitdidthat did you open the event cover high enough and did you try tge toggle switch,
The cover has a switch so the fan will not turn on if not open enough.
The toggle switch is 3 position. OUT, OFF, IN.Good luck
There's a limit switch in the fan body on the roof that only allows electricity to flow to the fan when the cover is partially open. It might be stuck. I spent a half a day working on my fan before i got a ladder and worked that switch a couple of times. A squirt of WD-40 fixed it.
It sounds like a connection issue. Since you did troubleshoot the fuses,etc. and lifted the vent cover tI the full open position and the fan still doesn’t operate I would pull the decorative plastic ring out that goes around the lower portion of the fan, take a screwdriver and pull the wiring out and check the splices out for connectivity. Sometimes the splices come apart from road travel and bouncing if they haven’t been properly crimped. And if you are getting voltage to that point and the splices are good you can then replace the fan.
Sorry for the late reply. As many have said and Nucamp did as well, change the fuse.....Even if it looks ok, start there. Bullet fuse on the unit was no bueno.
2021 Tag Boondock
@ididntknowitdidthat said:
Sorry for the late reply. As many have said and Nucamp did as well, change the fuse.....Even if it looks ok, start there. Bullet fuse on the unit was no bueno.Good deal, glad you resolved your issue!
- 194 Camping & Travel
- 72 Tips & Tricks
