DIY Tire Table
Hi all! I finished my project to create a tire table, and tested it out last weekend - a hit!
Here are the pix. I used 1/2" PVC and Lowe's had Armstrong stick-on floor tile on clearance that I loved, so I got four tiles for $1.09 each to cover the top. I need to add a second coat of paint, and also going to add foam "grippers" to the tire mount area just for extra stability as it did move a bit when I purposely tried to make it do so. Also added a rubber table leg cap to the leg, and will get a pipe clamp/strap to anchor the leg for travel. I LOVE the real TireTable but there is not enough clearance in the NuCamp wheelwell, so this is a good compromise!
It held, at various times, a 24" flatscreen TV, a mix of bowls and pans of food and dishes, a full garbage can, and dog leashes and food bowls.
