Keder Rails on T@G
Does anyone know of a clip that can be put in the keder rail such that I could tie a guy line to it? I typically like to put up a tarp on one side with telescoping poles The challenge is getting it secured to the camper. I use guy lines tied to the grommets on the tarp and have to pull them across the top of the camper and down to the bottom of the other side: the back lines attach to the stabilizer assembly and the front attach to the handles or the front deck. Thank you!
    JamesDow Member Posts: 755
    I do not have Keder rails installed on my 2018 5-foot wide standard T@G.
    I clean some spots and use four suction cups with a tarp and then other end of tarp held up by poles.
    My poles are just PVC with 2-foot rebar driven in the ground to hold them. No guy-wires or lines needed.
    Even in some strong winds, the suction cups and poles have not failed.
  • DebS
    DebS Member Posts: 12
    Thank you for the reply. I have bought many suction cups and cannot get them to hold — much less in wind.
  • ras
    ras Member Posts: 213
    edited June 2023
    I successfully use suction cups too. I think cleaning the location with windex and a rag or a window wipe before placement is the key.. Edited. I use exactly the same suction cups as GulfCoast below, I have traveled thousands of miles with them clamped to the roof of our T@G.
  • GulfCoast
    GulfCoast Member Posts: 109
    We bought a set of these heavy duty suction cups to anchor an awning. They stay attached for months.
    https://www.amazon.com/gp/product/B08N13T8X2
    I like @JamesDow's rebar and PVC pipe idea. Simplicity is a good thing.
  • DebS
    I have those same suction cups. I'm going to try and clean them with alcohol and then clean the roof locations, as I have not had success getting these to stay on.
    Yes, I do like the rebar idea. That assumes, though, you can get the rebar into the ground.
    edited June 2023
    We use these for our Sun shelter:
    iRomic Heavy Duty Vacuum Suction Cups Hooks (4Pack) Specialized for Kitchen&Bathroom&Restroom Organization
    Touch the image to zoom in
    Brand: iRomic
    4.4 4.4 out of 5 stars 1,245 ratings
    Amazon's
    Choice
    in Home Storage Kitchen Towel Hooks by iRomic
    -24% $15.99$15.99 ($4.00$4.00 / Count)
    List Price: $20.99$20.99
    Same-Day
    FREE Returns
  • rcarey
    rcarey Member Posts: 3
    I would caution using suction cups. I have an outdoor changing room mounted on the rack that came with my Tag XL. On a recent trip to Idaho, I was using suction cups to secure parts of the room to my Tag. The suction cups on the sides were fine. I did use one on the roof as well. I noticed the one I used on the roof now has permanently left a circle in the paint where the suction cups was. I speculate that the suction cup on the top was exposed to more heat due to direct sunlight and was the cause of the damage to the paint. YMMV.
    edited June 2023
    @rcarey, my suction cups are clear and have been exposed to very high desert sun and my T@G has not experienced any marks or discoloring.
    Were your suction cups clear?
    I experenced discoloring on my car by placing a black water/shower bag on it. After about 8 months it finally faded away.
    Thanks for the word of caution.
