Tagxl 2018 fridge slide drawer
dpyo4812
Member Posts: 15
I have an issue fro a recent trip where one my slides lost a screw now that side will pullout or keeps me from pulling out my fridge. Is there a way to separate the slide from the slide attached to the base. See photos
@dpyo4812 Sorry to hear about your issue and no one had a comment to help you. I know this happened back in 2023, but believe it or not that just happened to me tonight when I pulled into the camp ground. My trailer is also a 2018 and I have never had any issues. If you’re still on the blog and resolved the issue I sure need some help. Thanks so much.
Same type issue with my 2018. It is the screw(s) causing the issue. Look hard (really hard) and I would bet you will find a screw in the track.once removed and put back in place, it should solve the problem. I backed out each screw and put glue on threads. Reiserted screws all the way and have not had any repeat issues. (Don't over tighten)
Best of luck.
