How do I get rid of the squeak in my parked Tag? Lubricate the leaf spring? Thanks.
jeannelb
Member Posts: 2
Hi--Our 2021 NuCamp Tag Boondock trailer has developed a squeak that is detected while the unit is parked and is rocked or when we get in or out of the inside. It seems to come from one of the tires. Is this a bushing/leaf spring issue? What do you recommend?
Thanks.
Thanks.
Answers
Sounds like this is the perfect test for you to know if you have the (crank down) stabilizers set "just right." When the squeaking stops you have applied just enough oomph to the stabilizers.
You could try to lubricate the trailing arm suspension (no leaf springs in the 2021 model, I believe) inside the torque tubes. I'm not sure how that is done.
It would be good to rule out wheel bearing play/noise, also. Pull/push on the top and sides of tire and see if you get the noise/squeak or feel a clunking/thudding sensation. If so, it's likely time to work on the bearings.
TV: Volvo XC-60 T8 R
