It's snowing. Draining the tank and system.
Well, it's a day for draining the tank. The temp is hovering (has been for a couple days) near 30 or so. I haven't been worried about freezing damage as the trailer is plugged into the garage and I have the furnace in the trailer set at 65, but there's no use putting it off. I unplugged, hooked up and backed the trailer downhill, then pulled the drain valve. I'll wait an hour, then pull the filter and drain the pump by running it until it cavitates. I have already drained the hose for the water balloon filler so that's that. I will be heading out to Ft Robinson, Ne. in 3 weeks but I'll carry water in the Jeep as I expect sub-freezing temps there as well.
    Last time (first time) I drain the tank and pump till cavitation last year, I was surprised to see that water was remaining when I unscrew the inner and outer hose from the pump.
    Yeah, I always drain the hoses off the pump as a last step. Never get it all though.
    edited October 2018
    I put the old girl in the barn yesterday, fed her some oats and hay and put a blanket over her to keep her warm. =)
    Clearance height on my 400 is 110" so I had to enlarge the barn opening too last week and that proved to be an interesting and trying project.
    edited October 2018
    Mike,
    As the remodeling carpenter said to the homeowner: "No problem! We'll just zip a few inches off with the sawzall...is that a plumbing line?, hmmmm.and some electric wires there...zzzzt,zzzzzt....smoke...and why did they run the phone line through the doorframe?...hmmm...there's a steel I-beam under the trim in that header.....better get a jack....and a welder...." Homeowner leaves to get more bourbon, gaviscon...and money...
  • ontheroad
    ontheroad Member Posts: 190
    Congrats on the 400...Michigan Mike! Triple B is also in her winter resting place...pretty pink cocktail inside her! CHEERS!
    2018 Nissan Pathfinder
