Having problems removing the trailer hitch from the ball?
This seems to be a common issue we hear on the forum area. This video should help you out and explains what is happening when you have problems getting the hitch off the ball.
https://www.youtube.com/watch?v=Zq3f8b37laQ
  • ontheroad
    ontheroad Member Posts: 190
    thanks Mike!
  • Butch
    Butch Member Posts: 14
    Thank you!
  • beaky
    beaky Member Posts: 283
    I have seen groms pull into camp sites and unhitch large trailers without chocking the wheels, with the result that the trailer starts rolling away from the TV
  • Gerald98053
    Gerald98053 Member Posts: 25
    I never heard of Hitch Ball Grease until I upgraded to a much larger TT. Put a thin coat of grease on the ball before hitching up. That reduced my difficulties unhitching with the big trailer but sometimes I still have to pull the TV forward a half inch and back a half inch a couple of times. With the TAG I can just pull firmly forward on the trailer handle, then push back and it has never stayed stuck.
    Gerald
    Redmond, Washington
    Nissan Armada
  • Frogger
    Frogger Member Posts: 156
    Thanks MM...
    This is why you alway remove the chaines after unhitching. 😉
  • GigHarborTom
    Saw a guy come around a corner in friend neighborhood with ski boat on board.
    That is when I learned to grease the ball. The boat ended up in my friends yard upside down.
