Rear low pressure gas quick disconnect????
We have a 2021 T@G XL with a low pressure gas quick disconnect located under the galley bumper. Would like to hook up our fire pit to this outlet if possible. Can anyone tell me if this line be used for a propane fire pit??
If so, can you let me know what I need to complete the connection from the fire pit to the quick disconnect.
I have made a few inquiries at local trailer dealers and no one seems to know much about such a outlet. It seems to be a bit of a mystery...
A propane and gas appliance company will probably be of better help for this. But the output line might be to little for a fire pit.
Search the forum for gas quick connect. You'll find the info you need.
Check out this thread. https://teardrop-trailers.vanillacommunity.com/discussion/comment/9024#Comment_9024
In general, the propane quick connect port is already pressure regulated. If you attach anything with a regulator, the pressure/flow will be too low. You need to find something that allows you to remove the regulator and convert it to a quick connect fitting.
https://tab-rv.vanillacommunity.com/discussion/11344/new-propane-port-on-2021-t-b-320
