leaks in the corner of the galley door when in the upright position.
dpgunner
dpgunner Member Posts: 4
edited September 2021 in Trailers & Towing
After a heavy rain, when I put the galley door in the upright position, I get drips coming out the corners of the upright door and sometimes the dome light. 2018 TAG XL Boondock. where do i re-seal?
    JamesDow Member Posts: 751
    I would start with obvious points. Don't forget the license plate area.
  • JohnnyLoco
    JohnnyLoco Member Posts: 195
    edited October 2021
    Seal the tops of the trim piece over the hinge fabric for starts. I silicone the tops of everything on the trailer. Lights, window frames, side fan bells, everything. Additionally you can adjust the locking mechanism to make sure its tight enough to prevent driving rain around the seal of the hatch.
    These trailers are full of Bozo No-No’s
