Finished our new front storage box
Needed a way to carry our new generator (won't fit in the MINI) so we swapped out the box. Really happy with how it came out. Cut some 3 inch holes in the back corners and added screened soffit vents. Fashioned a rectangle out of some light angle iron to keep the battery in place and mounted the Zamp socket for the solar panels under the right rear corner. Still need to mount some anchor points for bungee cords to keep the gennie and gas can in place. Tongue weight is right at 160 lbs as pictured with an empty galley and dry water tank.
