different ways to charge
I have just purchased a new 2022 TAG XL Boondock. I am a little uncertain as to how the charging system works. The house battery can be charged 3 ways: (1) shore power; (2) by the rooftop solar panel; (3) by the car alternator while driving; Do all 3 methods charge with the battery switch OFF? I thought I read somewhere that the switch should be ON for the TV alternator to charge. I have to assume that the solar panel will charge while using the battery and the switch is obviously on.
The factory installed solar is wired directly to the battery and is not impacted by the switch.
The switch turned “off” isolates the battery from shorepower, 7 pin charging and from parasitic battery drain due to various devices that constantly draw power (USBs, LEDS, etc). Not only does the switch turned “on” allow for charging via the 7 pin, but it is required for the emergency break-away brakes to receive power in the event of a complete separation from the TV. So, yes, always tow with the switch turned “on”.(And just to be complete - make sure you have an installed charge wire as part of your hitch harness. I’ve heard more than a few stories of owners discovering a charge wire was not included in their hitch installation.)
