No Power from Battery
Mbastian
Member Posts: 5
I have a 2017 Tag and all lights and appliances work with shore power but everything is dead with battery power. Battery is charged and I replaced the fuses on the positive battery cable and in the panel inside the camper.
What is the problem and how do I fix it?
Thanks,
Mike B
Try disconnecting the battery and then reconnecting it. That often gives it the "reboot" it needs to start working again after changing the fuses.
2012 Subaru Outback -
Check out this thread @Mbastian - same problem.
https://teardrop-trailers.vanillacommunity.com/discussion/comment/6259#Comment_6259Sharon - Westlake, Ohio | 2017 TaB CSS -
