Galley Cabinetry Removal
CapnArt
CapnArt Member Posts: 14
edited October 2022 in Modifications & Upgrades
Has anyone removed the galley/cabin cabinetry to access the airspace between the galley and sleeping cabin on a T@G? I have a 2022 Boondock 5' Wide, and I want to remove the heater, and install a diesel fired forced air unit. Having to be plugged in, or use the genset, for heat, doesn't seem very 'Boondock'!
2022 T@g Boondock 5 - Childsplay
  • ras
    ras Member Posts: 213
    I'm curious. Why diesel when you already have propane?
  • CapnArt
    Using a propane heater in such a small space will cause a lot of dampness issues. Propane releases water vapour when it burns. Diesel doesn't. I've used these heaters on boats for years, and they're very efficient.
  • GulfCoast
    GulfCoast Member Posts: 109
    All combustion processes produce water vapor. Diesel fuel is no exception.
    Are you comparing propane heaters that burn directly inside the heated space with a Diesel heater that heats the space via a heat exchanger?
  • ras
    Since you need to have the windows and the vent cracked anyway to dispel moisture, I just don't see the advantage. But I have no experience with diesel heaters.
  • CapnArt
    Well, I've used the trailer for 3 nights prior to the Easter weekend, and it's brilliant! It was -6C - -8C overnights, and 19C in my trailer. Sips fuel and produces hot, dry, enjoyment!
