Solar Panel install
RayjoeJim
Member Posts: 16
Solar installed for about $200, mounted solar controller near battery box.
Subaru Crosstrek 2016
How did you route the wiring from the panel to the controller? Is that a plastic pipe conduit?
The plastic pipe conduit is from the preinstalled Zamp connector. I just cut the wires and connected to the output of the solar controller; it was already wired to the battery. I ran the wires from the panel to the input of the solar controller along the front of the trailer (see photo below).
