TV stolen! What bracket to get?
While parked at the dealership getting some repairs, my Tag was broken into and the TV was stolen. I need to figure out what kind of mount Nucamp used on their 2019 Tag Jenson TV’s. The thief left the base bracket on the door, but the stuff attached to the back of the TV is missing. If someone can post a link to the item on Amazon, I’d appreciate it.
Sorry to learn of your theft.
I think you should decide on the replacement television first and then if you need any other special tilt needs/wants.
Below is what I would consider and the best I could find on what may have been used on your 2017 T@G. I would not want to spend that much on a mount.
Goodluck.
Amazon.com: Mount-It! Small TV Monitor Wall Mount | RV TV Mount | Quick Release | Fits 13 15 17 19 20 21.5 24 25 27 32 Inch Screens | 75 100 VESA Compatible | Low-Profile Slim Design | 30lb Capacity : Electronics
ORIGINAL???
MORryde Snap In Wall RV TV Mount - Fixed - 35 lbs MORryde RV TV Mount MR85ZR
If it was at the dealers, they should have "garage keeper liability insurance". They are responsible for trailers in the process of repair. Once you turn the keys over to them, it becomes their responsibility.
If that be the case, I would push the dealer on it. Maybe a price break on the work being done. May want to make a police report.
You’re right, James. They actually paid for a replacement TV and bracket, but don’t know what the actual bracket is, apparently. They ordered one and it’s not even close. I’m trying to save a lot of time and effort.
Well, if you want the same mount, I would checkout - MORryde Snap In Wall RV TV Mount - Fixed. (see link in previous post)
It appears to be potentially same as the stock T@G mount.
Rich, I measured what Mount I have and found that this MORryde mount appears to be same dimensions (unlike the first larger one I identified.)
See below:
MORryde TV1-051H Snap-in TV Wall Mount - Small Rigid
Check this out! https://a.co/d/9qLd1Og
awesome! That’s it! Thanks James. Saved us a lot of headache! Lol
