Blackstone Griddle - Works With 2023 T@G XL?
Hey folks,
First time camper...first time poster! Happy to meet all of you!
Question: Will a 12,500 BTU Blackstone 17" griddle work with the 10,000 BTU output on the rear propane connection of the 2023 T@G XL Boondock? Any safety issues with this, and will the griddle get hot enough due to the limitation of the propane BTU output on the camper?
Thanks in advance.
It'll work. You're not going to operate the griddle wide open unless you're planning to burn everything you cook. You'll be operating at a fraction of the rated BTUs.
@ras said:
It'll work. You're not going to operate the griddle wide open unless you're planning to burn everything you cook. You'll be operating at a fraction of the rated BTUs.Fantastic! Thank you very much.
Verified: The 17" Blackstone table top griddle works just fine with the rear propane port on the 2023 T@G XL Boondock, when used with the following hose:
https://www.amazon.com/gp/product/B081VYGNDQ/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
