Subaru Forrester as a Tow Vehicle for TAG XL
dpgunner
dpgunner Member Posts: 4
edited May 2022 in Trailers & Towing
Love to save some gas money. At the tow limits. Anyone use one?
  • Speckman
    Speckman Member Posts: 19
    We tow our xl with Subaru assent. We carry a lot of weight on out tongue that even the Outback couldn’t handle. If you keep everything light you might do fine.
  • Sharon_is_SAM
    You really don’t want to max out on tow weights. Sure, you may be able to tow on the flat, but can you stop or maneuver suddenly?
  • Fourman110
    Fourman110 Member Posts: 230
    I used to tow my Boondock Xl with a 2017 Outback. Worked OK but the RPMs were always a bit high and gas mileage took a huge nosedive (and I live 8n the flattish terrain of Iowa). That Subaru ended up saving my kids and my lives. Upgraded to an Ascent and it tows so much better. Hardly know it's there. Took it through the mountains to Gettysburg and it just purred along.
  • The_Rigger
    The_Rigger Member Posts: 204
    You don't specify what year your Fozzie is, but the limit is 1,500 lbs (150 lbs. tongue weight) unless you're sporting a '23 Wilderness Edition, which is 3,000 lbs.
  • evpeeling
    evpeeling Member Posts: 69
    I used to tow with a 2011 forester that had a rating of 2,400. It did the job, but it was pretty slow. I also felt like it was taking a toll on the transmission.
  • zgfiredude
    zgfiredude Member Posts: 215
    I am just not thinking the cvt transmission will be happy about it.
  • ksCamping
    ksCamping Member Posts: 1
    We tow our T@G with a 2013 Forester. The 2014-present are rated to tow way less than ours. It works but we certainly won't be heading to the mountains anytime soon. Our next car will have a bigger engine and higher tow rating. (Unfortunately more $$)
  • JimJ
    JimJ Member Posts: 3
    The CVT trans is what I would worry about!
  • GulfCoast
    GulfCoast Member Posts: 109
    There are a few discussions on the Subaru Forester forum about CVT transmissions and towing. Our 2.5 liter Outback seems to handle the T&G just fine.
    https://www.subaruforester.org/
  • The_Rigger
    edited September 2023
    Yep; my Outback has no trouble towing my T@G either, aside from the fuel economy going right into the toilet...
  • Does anyone know when brakes were added to the T@Gs? Some used ones have them and some don’t!
    '06 T@B, '13 Subaru Outback, '12 Golf TDI
  • Sharon_is_SAM
    I believe they became standard with the 2018 models.
    JamesDow Member Posts: 750
    My 2018 5 wide standard does not have brakes. It falls below the weight requirement.
