Television Mount?
Good morning, helpful and fabulous T@Ggers!
How the heck do I mount my television in a 2023 Boondock 5w? The "tv prep" cabinet opens up toward the ceiling and its outlet is totally blocked by the A/C. I didn't see a solution in the posts. Am I just missing something obvious?!?!
  • Jay
    Jay Member Posts: 76
    Change the direction of the door swing to left or right instead of up.
  • JLH
    JLH Member Posts: 21
    Yep! Something obvious. Thanks, Jay.
  • The_Rigger
    The_Rigger Member Posts: 203
    edited November 2023
    I seem to recall the factory TV fit-kit was exactly that; they sell you a center cabinet door with pre-hung latch & hinges that swung open from the side instead of the top. You'll need to check with a local Parts Dept, as nüCamp won't sell direct-to-consumer.
  • JLH
    I'm also tempted to just remove the door entirely and put a mount on the inside of the cabinet. The TV is larger than the opening, so you won't see it doesn't have a door. And, as long as the TV mount swings or extends, I can still access the space for storage.
    The electrical seems a larger problem. I'm not sure the a/c plug will fit into the two gang receptacle without covering both plugs. That would mean drilling holes to pull the cord to the outlet by the fuse box.
  • Jay
    I have a friend who has a 2021 and it swung up. The dealer added a TV and didn't change the swing. He couldn't use the door. I changed the swing to open on the right, hinges on the left, works just fine now. Bought 2 new hinges, added a support for them, added a door latch.
