Battery disconnect problem?
Hi ya’ll. Need help analyzing why my 2017 TAG boondock isn’t getting power from my fully charged battery. Details: worked fine past week. Before new trip, I charged the 100 Ah lithium battery w/ plugin outlet charger and then hooked up battery in camper. Then hooked camper up to shore power to get cooler going while packing. Then hooked up 7-pin. Disconnected shore power and drove to campsite. I believe (think) the battery disconnect was on all through all these (unfortunately?).
Got to campsite and there’s no electricity to any camper accessories (LED lights, cooler, fan, nada). Checked connections on battery, checked fuses on converter, checked breaker switches. All good.
Only thing I can think of is that the battery disconnect switch is out. Thoughts? Advice? Please!!!
  • The_Rigger
    The_Rigger Member Posts: 204
    edited July 2024
    If the fuses are all good, it may be the switch is bad, or possibly a wire came disconnected somewhere.
  • Lyndall
    Lyndall Member Posts: 6
    So….rechecked the fuses when I got home and, indeed, one was blown. Now I know use a flashlight to backlight vs. evening sky . Duh. Thanks everyone
  • ras
    ras Member Posts: 213
    I carry an inexpensive multimeter to check voltages, fuses and connections.  You can learn how use one on youtube
  • The_Rigger
    edited July 2024
    They make ATC and ATO blade-type fuses that have a tiny LED onboard that lights up when the main fuse link blows, making it easy to spot an open circuit. This might be the perfect application for those fuses.
    FWIW, the newer WFCO power centers have LED blown-fuse indicators right on the circuit board next to the fuses; makes it really easy to spot a dead fuse.
  • Lyndall
    Well damn. Happened again. Full battery replaced all fuses (even though they weren’t blown). No power in TAG. Wires underneath look fine.
  • GulfCoast
    GulfCoast Member Posts: 109
    Were you able to get things working after the initial problem? What seemed to be the fix?
    Do you have a volt-ohm meter? I'd start at the battery and confirm voltage at each step along the circuits to the end use points.
    Even if voltage is good, you may have a high-resistance connection that doesn't allow adequate current to flow. But checking voltage is a good start.
    Be aware that poor ground connections can also create problems.
  • Sharon_is_SAM
    This is intermittent.  I would closely inspect the wiring coming out of the power center.  Look for a loose connection.  It happens!
