2024 t@g boondock black canyon
Laylatrkdrvr
Member Posts: 3
I bought this camper lightly used just a couple months ago from an individual. I can not, for the life of me, figure out how to get the little water heater under the sink to warm up my water? I understand it only gets warm and not hot, but I can’t even get it to warm? I switch the switch both ways, let the water run forever in both hot and cold, switch in up and down position, and no change. Any suggestions? Anyone else have this problem?
https://www.reddit.com/r/TeardropTrailers/comments/1gxh54w/hot_water_heater_why_am_not_getting_hot_water/
Looks like you need shore power. It is electric. -
I also just got a 2024 T@g 5-wide, and we took it on our first trip. Was able to plug the trailer into our Jackery 1000v2 to power the hot water so my better half could get a shower. What I don't know is if the hot water is/can be routed into the external shower line.
You were able to get constant hot water from the faucet?
I get about 5 seconds of the warm water, then it turns to cold
Enough warmish water for an intermittent-type shower (turning water off when not necessary, etc.), yes. If it had been 40 degrees out, it would not have been optimal.Laylatrkdrvr said:You were able to get constant hot water from the faucet?
