2021 T@G - Crane Heater
Triton46
Member Posts: 29
My T@G did not come with the remote control for the Crane heater. I'm presuming that's the issue of why the heat will not turn on.
Q1) Would buying a new Nashone remote pair with the existing wall plug behind the cabinet?
Q2) Is there a fairly detailed write up on accessing the Nashone plug? I'm aware of where the plug is, but not which cabinet pieces to remove to access it. The less the better!
I received a response from Nucamp on these questions:
1) Yes, a new Nashone remote should pair with the existing Nashone plug, assuming everything is working.
2) Disassembling the cabinet should not be needed to reach the Nashone plug. It should be reachable by removing i̶̶n̶̶t̶̶e̶̶r̶̶n̶̶a̶̶l̶̶ f̶̶a̶̶r̶̶ l̶̶e̶̶f̶̶t̶̶ s̶̶p̶̶e̶̶a̶̶k̶̶e̶̶r̶̶ i̶̶n̶̶ t̶̶h̶̶e̶̶ c̶̶a̶̶b̶̶i̶̶n̶ the galley speaker on the right directly behind the Crane heater. -
New remote connected to the existing Nashone outlet plug. I did realize after setting up for camp that the interior speaker is on the opposite wall. I'll get clarity from Nucamp.
I just received a response from Nucamp on #2. The wiring for the Nashone plug should be reached by removing the speaker in the galley on the far right as you face the galley. That speaker is behind the vicinity of the Crane heater.
