Water leak
Beerwidow
Member Posts: 2
Hi all. Just purchased a used 2018 T@g and am working my way through the systems. Hooked up city water just fine but when filling the water tank, water was leaking through the outlet next to the sink drain. Do I have a leak in the tank itself or am I missing something? The tank never seemed to fill beyond half way and there was visible water around the bottom edges of the tank itself.
If it is the tank, any recommendations for fixes? Replace with similar or something after market?
Hey Beer. That's the drain for when you want to drain the water holding tank
Directly above that , inside , next to the tank you will see a valve that activates by lifting up to open or push down to close
Take care
mike -
Thanks for the reply. Yes, had to trace all the plumbing again to figure out that it was the drain for the tank & also fix a leak at the input to the tank.
