ADDING ELECTRIC BRAKES
MikeRog
Member Posts: 8
Evening all
Have a 2014 Little Guy 5 Wide and thinking about adding electric brakes. It has a Dexter 2200# torsion axle, Tire Size is P175 80R13 with a 5 lug hub , 5 on 4.5. The brakes would be 7 1/4" . The mechanics of installing the brakes would be fairly simple . Finding the blue brake wire may be more problematic. If anybody has any suggestions or ideas they would be greatly appreciated
Thanks
mike
Thanks
mike
The connections from the seven pin connector terminate in a black box on the driver side of your T@G just forward of the decal for the Zamp connector. You should be able to see the back of it protruding below the frame. You'll have to crawl under the tag to open it and view the connections.
Thanks raz
- 194 Camping & Travel
- 72 Tips & Tricks
