Propane Tank Delete
I'm seriously considering modding my stove to use the smaller and easier to use (and refill) 1lb propane bottles. My initial idea is to put/connect the bottle under the sink and get rid of the big bulky 20lb tank off of the tongue. I'm pretty sure the existing line goes behind the microwave, so I will have to deal with that.
Has anyone done this or have any opinions?
Thanks,
Greg
Thanks,
Greg
1st TV 2015 MB GL450
2nd TV 2016 Mazda CX-5
    Gregg,
    I am a big fan of ditching the 20lb tank and have done that on my T@G. Previous to moving up from my LG to the T@G I switched up on my Little Guy from the 1 lb to a 5 lb bottle. The convenience of the 1lb cylinder was nice but I found that they were not able to run my kitchen in cold weather. It would take much longer to cook anything and a full 1 lb bottle wouldn't boil water at all. Since going to a 5 lb cylinder I've had zero problems even in sub-freezing weather. If you only camp in warm (over 40 degree) temps the small bottles work great. Just something to consider...
    Otis_60Otis_60 Member Posts: 37
    A majority of my camping is done above 40 degrees, so that should not be much of an issue.
    Thanks,
    Greg
    I always worry about refuelli g 1lbs bottle. They are not made for this. I have seen new ones that were leeking after removing them from a lantern. Found out that my plastic tote would smell propane once I would reopen it after storage.
    Refuling means reusing a vavle that only shut by loaded spring.
    And for what it is worth, it is supposed to be illegal to refill them. But that is an other story.
    I am like William. If I make the switch, I will transplant my 5 lbs bottle that I use on my off raod trailer to my T@G.
    TomDTomD Member Posts: 358
    Greg...My 2015 SS came plumbed for lpg the way you want to do it. Works fine. However, you MUST remember to remove the canister before departing. I have a 5lb tank as well but use it for the little red campfire
    WilliWilli Member Posts: 22
    I switched from the 20# tank to the 1#. Haven’t had any issues with the changes. Regarding below 40 degrees..... I would not be camping! Lol
    Fort Myers FL.
    Our bottle regulator screws right on the appliance regulator under the stove. Add a 1 lb adapter and a bottle stand and you're good to go.
    Thanks for all the comments. I think I am going to go ahead with this.
    Thanks,
    Greg
    Regardless of what you do, make sure you vent the area as propane is heavier than air and will settle into a confined space and can ignite if a source or spark or static electricity occurs.
    BillyTBillyT Member Posts: 2
    do I still use the regulator from the factory? or is the one in your picture another one?
    LightningdonLightningdon Member Posts: 110
    I also deleted the 20lb tank and switched to a 1 lb tank, but just used an adapter and keep it in the tongue box.
    daveandcorlenedaveandcorlene Member Posts: 74
    Awesome twin batteries in series setup!
    2021 TAG XL Boondock
    Toyota Tacoma
    Evergreen State
    Looks like my Boondock as well. Easy mod (propane). Just a tip to anyone doing the change.... the mod itself is about a zero on a scale from one to ten. Just be careful that you remove the 1lb cylinder from the adapter not the adapter from the 20lb tank connector. Accidentally did that once and a lot of very cold propane came jetting out, dislodging a rubber seal..I made the mistake of thinking the seal went on the 20lb connector side and couldn’t get a cylinder to seal. Turns out that seal goes in the adapter. Once I put it in the right place it was back to perfect.
    Come to think of it, I should tape the 20lb tank connector to the adaptor to ensure I don’t make that mistake again.....
