2017 T@G XL Wheel Lube Plan
Hi, We bought a 2017 T@G XL Outback last year and drove it about 5k. The previous owner had it in a garage for about four years and never used it. He bought it from a dealer used. We have not lubed or repacked the wheel bearings and just realized we should do that prior to another cross country trip in a few weeks. No one seems to be available locally to do it in the time we have so my plan is to put new grease in (it has the EZ Lube system). Then I will buy the replacement seals and bearings and keep with me in case we have trouble. Maybe I will attempt the full repack when we get to our destination. Does that sound like a reasonable plan or am I tempting fate by not doing the full repack?
  • Have you felt the hubs during your trips to see how hot they feel? Sitting four years without moving is a long time and hard on the bearings. And the grease is pretty old now too. Do the brakes still work? If you do re-grease and head out, I would stop often and check the temperature of the hubs (by thermometer if you have one but by feel if not). I would also be very concerned if the tires are original. Those tires would be about 10 years old now since date of manufacture - way past the recommended lifetime of a tire. And sitting for four years they may have developed flat spots. A blowout or bearing failure could be catastrophic on the highway (we've all seen photos), so I would replace the bearings, seals, and grease before you head out on this trip so as to not tempt fate. And the tires too if they haven't been replaced. And have the brakes checked. A few weeks before departure should give enough time to have this work done. I'd skip the RV shops and find a local reputable tire shop with a lot of trailer experience. We're lucky we have one nearby. We're having new tires put on ourselves in a couple of days. Good luck and happy camping!
  • Thanks for the advice. So far no tire shops willing to do the wheel bearings. I’ll have the tires looked at but they seem good. It’s an outback and the treads are pretty beefy.  I did check the hubs regularly by hand and they were fine. I did buy a thermometer tho.
  • I regrease my 2015 T@B every year using the EZ-Lube. I've only once disassembled the hubs and repacked manually--maybe about six or seven years in--and everything looked fine. It's probably time to get eyes on those bearings again, but my point being that the EZ-Lube works if used properly. Opinions--and your mileage--may vary!
    If you do use the EZ-Lube, just proceed carefully until it's obvious the grease is flowing freely and emerging from the front of the hub. If something is blocked you might risk blowing out a rear seal if you force things, but this is unlikely.
    Keep the wheel turning and add new grease until the old grease is completely forced out. Keep lots of rags handy--haha.
    Everyone has different risk tolerance--and there are no guarantees--but do this (and keep monitoring your hub temps) and I'll gamble you'll be fine.
  • I purchased an inexpensive infrared thermometer from Harbor Freight and use it to monitor hub temperatures when I stop for fuel.  When the temperatures start cliimbing, I know it's time for easy lube.  The wheel bearings and seals to for my 2016 T@G were available at my local Northern Tool.  I carry one set with me .   Also check the temps of the hubs on my 4Runner with the thermometer.  They run much hotter in normal operation.  Probably reading brake generated heat
  • I put Bearing Buddies on my camper. They work fine.
  • Thanks all! FYI, we regreased through the EZ Lube Zerks and the hubs never got even warm to the touch after several thousand miles. I have all the tools and the parts, and am thinking I may just keep an eye on them for now. I'm a tad concerned about pulling things apart 60 miles from the nearest town (45 on a dirt road) where we have no cell or internet. Seems like it might be safest to just keep an eye on it and do it when we get home.
    I do however have to replace the battery disconnect switch since a board shifted during the bouncy ride up the dirt road and snapped the knob off, which I had accidentally left in the off position. I'm learning the lessons the hard way! When we are home we will have slept in the T@g for most if not all of 6 weeks. Other than the disconnect issue it's been awesome. Also removed the AC, the microwave and tv since we don't use any of them.
  • Oh... one other bearing replacement question. We have trailer brakes... does that change anything with bearing replacement or make it harder?
  • Glad you got this done and things went well on your trip!
    Assuming T@Gs have some variant of the Alko/Dexter axle used on T@Bs, the brakes shouldn't affect your bearing work. However, many DIYers take the opportunity to inspect and service the brakes while things are apart.
    Not really, no. Just another level of Stuff To Check.
  • Hey Typing
    As an aid for future axle and bearing service this is what I did   On your axle there may be a Dexter sticker which
    has your axle serial number.  Call Dexter service with that number and they will send you by way of email a complete factory spec sheet of your axle. Bearing size inner and outer , seal number , brake specs etc .
    If you are a DIY you will find it very useful
    Take care
    mike
  • @MikeRog thanks. That’s a great idea! Doing that for sure.
    And thanks all for the responses! One more day of our trip. Looking forward to continuing to learn about maintaining the T@G.
