How do I test my T@G for a propane leak?
rlg
Member Posts: 2
Hi, I have a 2019 nuCamp T@G. I can smell propane by my stove, so I know I have a leak. Can someone help me understand how I can run a leak test? I've looked up how to run a time pressure drop test in an RV and ordered a manometer, but my small stove doesn't appear to have anywhere I can connect it to like in the videos I see online. Has anyone run this test before on their T@G? How did you do it?
I have a 2018, which does not have a safety valve associated with the galley hatch. I have never experienced a gas leak.
My best practice is to turn on my propane at the tank, when I intend to use it and turn it off when not in use. I highly recommend this process.
Make sure your stove knobs are set correctly to off.
Per my understanding, your 2019 has a electric solenoid safety valve linked to the rear galley/hatch area.
I would check the solenoid and connections first.
As for leak checking, my first choice would be some water, dish soap and a small paint brush or spray bottle. Brush/spray the mixture on any fittings, valves or anyplace you suspect a leak could come from. Bubbles will tell you you found a leak. This method should find the leak.
Second method would be using a hand held propane gas detector. Costs around $40 -$80 on Amazon. I have never used one, so I have no expectations.
A manometer may tell you that you have a leak, but may not tell you where. (Not much use)
While it will not detect propane, it may be a good time to check your carbon monixide detector to assure it is not expired. I replaced mine with a BRK CO250RVA (First Alert by same part no). Get one suitable for RV use.
Good luck on your leak hunt.
Keep the members on the forum informed as to your findings.
