Ratchet
In the nucamp black bag with all the manuals and remotes I found a 3/4 twelve point ratchet. Anyone know what this is for? I have looked over my Boondock but don't really see any place where this would be handy - I am probably overlooking something and I will not be surprised if I am. :)
Thanks,
  • Verna
    Verna Member Posts: 136
    3/4” is the size of the lug nuts.
  • tanda62
    tanda62 Member Posts: 38
    Okay, after putting on my glasses I now see this is from lowering and raising the spare tire from underneath.
    Another question though, what are you using for a jack if you do need to change a tire on the road?
  • Verna
    I have an 8 ton bottle jack from Harbor Freight that I used on my Silver Shadow to change tires. I prefer to call AAA, but I can change a tire if need be.
    As a side note, do not put a jack under the axle. Use the frame as a support for the jack. The axle is a rubber torsion axle and will bend if used with a jack.
  • mgreen2
    mgreen2 Member Posts: 193
    You should be able to use the jack on your TV
  • tanda62
    So today I used my garage floor jack to take off the tires and grease the hubs - amazing how much they took being new. Also surprised how much surface rust was on the drums and suspension - all better now with fresh paint.
    The jack from my TV (Subaru Outback) will not work as it does not extend enough. Maybe with some wood under it...
    I saw the notice about jacking under the frame not the axle, since this is a torsion bar axle you don't want to jack on it. My first car was a 1960 VW bug with a torsion bar front axle so I have some experience with the setup even though they are different in execution.
    This is fun working on my first camper! When I finish my restoration of my 1953 Dodge truck it should be fun to tow it with it.
  • TomD
    TomD Member Posts: 357
    If you’re thinking of changing tires yourself keep in mind that the torque on the wheel lug nuts is generally higher on a trailer than a car. This means that unless you have an assist (special tools, pneumatics, etc.) you better have Popeye arms and a can of spinach.
  • GigHarborTom
    13 inch tires 2017 T@G XL, what is the torque suppose to be? I have a torque wrench.
  • GigHarborTom
    From Trailer venders my 13" wheels should be 85 pounds torque
  • Michigan_Mike
    Any suggestions out there as to where I could find a reasonably priced or affordable torque wrench for lug nut torquing purposes, etc?
  • mgreen2
    NuCamp says 95 lbs
    https://youtu.be/knmD7uFW0mk
  • GigHarborTom
    Michigan Mike..I think I got mine from Harbor Freight or Home Depot
  • GigHarborTom
    Just ordered a new Torque wrench from Amazon. The go from 25 -40 bucks or so
