Electric Brakes
Bobl65
Member Posts: 4
I have a 2018 T@G with only about 1,000 miles on it and on our last trip out, our brakes started squealing really bad, I jacked up the trailer took the wheel off and inspected best I could and couldn't fine anything wrong, no rocks or anything like that. Any suggestions would be helpful.
@Bobl65, the brakes should be adjusted after the few hundred miles (the owner’s manual on the thumb drive will give you the correct interval). Your first choice for this service would be your dealer. If you can’t get to the dealer, look for a utility trailer dealer in your area, and they will be able to help you.
Thank you so much
