Water tank
Sparrow
Member Posts: 19
Anyone know if there is a retro fit or an mod to get the last of the water in the tank out. Or to even utilize it ? Once you start sucking air you can’t use the last 2/3 gallons in the tank 😕
http://teardrop-trailers.vanillacommunity.com/discussion/436/i-pumped-the-water-tank-dry/p1
@WilliamA might have more for you on this, this is his mod.
I do not have pics for my retrofit,,but I was able to find a pipe that Would fit directly imside the fitting. So it was unscrew install and screew back in, of almost.
