How do I edit a post?
Slh55
Slh55 Member Posts: 2
edited November 2017 in Help - Computer & System
I may be missing the instructions but how to I edit post. Thank you.
  • 2jgcampers
    2jgcampers Member Posts: 42
    Go to your post-see the wheel at the far right of the post's top line, tap and select edit, save!
    Twojs&Guinness&OD
  • Michigan_Mike
    As noted by Judi, click on the wheel in the RH corner and you can edit your text as needed.
  • Slh55
    Thank you. There was no wheel appearing on post when accessed many times, but the problem has now been resolved.
  • Michigan_Mike
    Good deal! I did hear that there was an issue and am glad it's been resolved. Thanks for making people aware of it.
