Bedding
sgreco29
sgreco29 Member Posts: 3
Greetings! My boyfriend and I just purchased the 2019 T@G Boondock Edge and we couldn't be more pumped about it! I'm wanting to know what size bedding is best for the size of the mattresses provided? Also, thoughts on memory foam mattress toppers?
  • Sharon_is_SAM
    This may help. Do you have a TaG (58" x 75") or TaG XL (78” x 75”) - bed sizes.
    https://teardrop-trailers.vanillacommunity.com/discussion/comment/2660#Comment_2660
  • sgreco29
    We have the XL
  • OutdoorEd
    OutdoorEd Member Posts: 109
    We have a 3 inch memory foam topper and it's very comfortable. I weigh 175-180 and I think if a person weighed much more another inch might be important.
    2018 Subaru Outback 3.6R
  • beaky
    beaky Member Posts: 283
    WalMart has microfiber RV sheets for $50 that work really well. We swapped out the twin pads in our XL for a queen memory foam that leaves a 12" space down my wifes side of the bed for her night stuff. Its also easier for her to lift the floor this way.
    As for the matress toper, I would suggest that you try it as is.
    I am 285 lbs, and I am very confy with the oem matress that we got with our T@G when new in 2017.
    Just try it, and them decide what you want.
    Enjoy your T@G! :)
  • Jay
    Jay Member Posts: 76
    We bought a mattress topper for our XL, king size and had to trim it to fit. We used a bread knife to cut and had not issues. We use king size sheets and tuck under the mattress, Also have a king size comforter for those chilly nights.
  • Michigan_Mike
    Testing here - 1-2-3!
    WilliamA Member Posts: 1,309
    Bueller? Bueller? Anyone?
  • poliver
    poliver Member Posts: 33
    Found a wonderful mattress manufacturer in Waterloo, Ontario CANADA. They were able to custom fit a foam topper and mattress cover for us. I suffer from back pain and the topper is a must as the stock mattresses are toothin and too soft (bottoming out ) that is what puts pressure on your shoulders and hips while you sleep. They also can make a custom mattress for our T@G when we need a NEW one. Great find and a very easy and adorable company to deal with.
    if your interested give them a call Waterloo mattress ask for Kathi.
  • Lightningdon
    I am running the stock mattress with a 2 inch memory foam topper under it and another on top of it.
