Sink/stove removal
Has anyone removed the combo sink/ 2 burner stove? We would gladly give those up for more counter space and storage in the cabinet, as we rarely use either.
If you have access to Facebook there is a "T@G your it" group there, you can search it, there are several folks that have done and discussed that mod, most with pictures. (know it's not helpful, but we would miss both and use the top of the Norcold and a Coleman folding table for extra counter space.)
I'll check it out. Thanks!
That shouldn’t be an issue. The stove in most of these units is just screwed into place with 4 screws that have rubber caps over them. I’m sure the sink is similar or it might be glued down, I’m not sure. Use a thin knife under the edge to break any seal, use a shim or screwdriver to keep the stove or sink up and you should be able to get the appliance out. I never liked the stove in the back as the area is close and if you had a fire it would be easy to lose the trailer. But on the flip side, others have used these stoves safely and without incident.
Post up some photos of your work as this will help others in the future. 👍🏻
