Water system maintenance
A beautiful day. I spent the morning doing a bit of chassis maintenance and the afternoon coaxing my recalcitrant pump to, well, pump. After two complete removals and teardowns, I found the sticky valve and got it unstuck. I also found some wonky connections (water) and tightened them up. With a bunch of found time on my hands, I've decided it's appropriate for a complete replumb. I want to move the pump down and put in all new pressure lines and fittings. I'm also going to add a priming port as I've been going to do for two years. I'll need to measure things and order up the hose and fittings. I'll post a how-to when that gets here.
In the meantime, the tank is full and being bleached. I'll pump it dry tomorrow and refill it....
  • HikinMike
    HikinMike Member Posts: 400
    Stay busy my friend. Down time is always a good time for maintenance and such.
