Cooler tray stuck!!
danger_don
danger_don Member Posts: 2
My cooler tray won’t push in! I’ve used for months and suddenly stuck. Happen to anyone else?
  • SueBHunny
    SueBHunny Member Posts: 135
    Make sure the frame it sits on is intact behind the cooler. Mine sometimes falls apart and then I have trouble with the slider.
  • ontheroad
    ontheroad Member Posts: 190
    Our left slider had a problem..the part that lets the drawer slides back was misaligned...ended up replacing the left drawer slides...all is well now..
  • Frogger
    Frogger Member Posts: 156
    I sprayed some "slide out" on my runners hoping that'll help keep 'em lubed & aligned; we'll see lol
    JamesDow Member Posts: 751
    I had some issues with my NoCold Slider on a recent trip. Ran some rough asphalt roads followed by dirt roads. (I drive slow over bumps when I see them)
    After investigation, I found a slider track screw had come loose and was jamming the track. (See Photo Below)
    After some work with a small screwdriver, I un-lodged the screw and put it back in place. I found some others screws holding the track in need to also be tightened some. (Not too tight)
    When I got home, I also found my side window frame ajar. Pulling off the corner trim, I found another screw loose again. Went around and checked all of the corners. (Do not over tighten)
    Looks like this kind of maintenance will be on my list.
    And on this trip my wife is correct in saying I have a screw loose.
    @JamesDow , good finds! 👍
  • HikinMike
    HikinMike Member Posts: 400
    Imma check mine now
