2014 5 wide little guy air conditioning duct hose
I just purchased a used little guy 5 wide that is set up for factory air conditioning.
Based on several posts on this board, I think I can modify a portable little 110 A/C unit when I have shore power.
But, after a bunch of internet searches I have not been able to find 3 1/2 inch hose to fit the existing flanges cut into the little guy wall.
Any one who has done this know where I can buy the hose?
    Go to climateright.com and open "other products" and then "replacement parts", the small hoses and other parts listed should help. I was going to try to add one of their portable units to our T@G (they are reverse cycle with heat!) but they have been out of stock forever and still are indefinitely. I ended up moving the window unit in our T@G to the window when we need A/C, takes a couple of minutes to set up and works so much better, also added a thermostat.
    davidreidokdavidreidok Member Posts: 2
    much appreciated
    I am a new little guy 5 wide owner and
    this board has helped me a lot.
