Mounting in galley
What is the best method for mounting hooks and paper towel racks on the backsplash area in the galley? Adhesive? Screws? What kind/size do you recommend?
2018 Mazda CX-5
2020 T@G 5w
Arlington, VA
I would suggest maybe 3M Command Hooks (see photo)
Clean the surface as instructed.For paper towels, I would investigate racks which can hang from cabinet door below sink. (see photo)
You may wish to place some tape on metal parts which contact the cabinet.
I would avoid travel with the rack hanging from the cabinet door.
Make sure the placement does not interfere with the hatch.» Whatever chosen, remember not to hang or place things flammable near the stove burners.
@nichutchy4 we had a 2017 which had a solid piece of wood perfect for screwing into...we had a couple of magnetic knife holders that were awesome..think it was a 5/8" #2 robertson that I used...
2018 Nissan Pathfinder -
I have used the 3M hooks from hanging my curtains to hanging pots & pans. So far they have worked well. I would recommend though rubbing the surface with some rubbing alcohol.
The wood sheet making the back splash is about 3/8 thick, so plenty sturdy. Just used screws that aren't too long and you are fine!
