Spare fuses
Can anyone list the spare fuses that would be good to have along in the T@G in case on blows?
Look at your converter and note what is plugged in and then add a 10 amp which is at the battery. You need to match the type of fuses.
For my 2018 my converter is a WFCO WF-8725
Fuses in that converter are;
2- 7.5Amp 1-15A, 1-20A, 1-30A (+1-10A)I purchased a variety pack on Amazon to have on stock.
(See Photos)
@JamesDow said:
You need to match the type of fuses.Thanks for that info!
I asked the tech at nuCamp and he said they use a 30 amp fuse at the battery. I wonder if the dealer replaces the fuse as they are the ones who install the battery.
Sharon_is_SAM;
You may be 100% correct.
I am not sure if I have even opened up the fuse at the battery to inspect. (my bad)
Well, I do know that it would not be unusual to find different size fuses most anywhere on the camper. Although I believe quality control has tightened up and there are fewer incidents of alternative fuse findings - at least in the Tabs😊
