add Hot Water Heater?
csonni
Member Posts: 354
Not sure why NuCamp doesn't give an option to heat the water. Has anyone checked into what it would take to actually heat the water or add an additional water tank that could be heated and have the stock faucet and exterior hose deliver it?
Or, replace the coiled hose with a hose that would direct the 8 gallons of water to a tankless hot water heater- https://www.thecabindepot.ca/collections/tankless-water-heaters.
Are there QuickConnect adapters made so one can connect a standard garden hose in place of the OEM coiled hose? I suppose the 55 psi would drop. -
You’d just need a smaller Inside Diameter hose to keep up pressure.
2017 Tag XL
Those Tankless Water Heaters don't require much pressure at all.
