Fantastic Fan Vent Cover
Has anyone installed the Fantastic Vent Ultra Breeze Cover on their Tag?
Looks like work to me! I have installed two of the Aeroflo vent covers and this requires no lap sealant, only installing some small L brackets which isn't too difficult.
on the wish list! at least some sort of vent cover
2018 Nissan Pathfinder -
@ontheroad said:
on the wish list! at least some sort of vent coverIt definitely DOES make a difference and that first rain event will make you a believer, especially if it is muggy and you need to run the fan!
will be adding one over the winter...unfortuneately we will have to take it off and on to get in the garage...dealer tried to look for low profile ones but never found any..
@ontheroad said:
will be adding one over the winter...unfortuneately we will have to take it off and on to get in the garage...dealer tried to look for low profile ones but never found any..Some people buy the small suction cups to stick them to the roof and use them that way so they can quickly remove them as needed.
@Michigan_Mike said:
The suction cups are a great idea! It makes for easy use when the vent is needed then put it away.
2017 T@G
Michigan
2020 Ford Explorer SE
This is the one I need to get. The important part of this install video for me was that it is held on with cotter pins. That means that I can easily take it off so I can get Otis in the garage.
Thanks,
Greg
1st TV 2015 MB GL450
2nd TV 2016 Mazda CX-5
@1luvFishing said:
Has anyone installed the Fantastic Vent Ultra Breeze Cover on their Tag?I took Mike's advice and went with Aero Flo. So glad I did. I am not mechanically inclined to say the least, but I was able to install the Aero Flo. I didn't have to drill holes in my T@g and it has a lower profile than the Fantastic Vent. Better than all that it still fits in my garage!
Looks good and eliminates the rain issue. Congrats!
I thought that the suction cups we a great idea. I went out and purchased a Camco vent cover (affordable) and also purchased clear suction cups w/wing nuts for quick attachment and removal when not needed. I am so glad I did get the cover since we encountered more rain this past weekend. The first time in the T@G we had heavy thunderstorms and had to close the vent. Fortunately, we had shore power hook up so we were able to run the A/C to help remove the humidity. Anyway, I appreciate the idea for easy on and off using the suction cups. Thank you!
2017 T@G
Michigan
Good deal, glad things worked out for you!
Hey all,
I'm curious if anyone has tried this one:While it's spendy, it would seem to be the perfect fit for a teardrop where maximum height (garage parking) and wind resistance are major factors.
@Cccjim said:
How did you install it without drilling holes? The fan on my T@G has a plastic frame, not the metal shown in the video. Can you add a photo of the installation?
@mgreen2 said:
How did you install it without drilling holes? The fan on my T@G has a plastic frame, not the metal shown in the video. Can you add a photo of the installation?I did drill "pilot holes" into the fan border plastic for the small Phillips head screws pictured. The small bolts come up under the installed bracket (held in place by the Phillips screws and then you simply screw the nuts onto the bolts. The instructions included with Aero Flo (I am a fan) were superb! Hope these pics help.
I am just throwing out an idea here. Has anyone tried to fab a soft version of this?? Something that could come up as you lift the cover and come down when well, you close the cover. I have a T@G with the Yakima rack, and adding this simply makes the rack useless, but I understand that it can be very useful.
I will have to look into that.
@LuckyJ said:
I am just throwing out an idea here. Has anyone tried to fab a soft version of this?? Something that could come up as you lift the cover and come down when well, you close the cover. I have a T@G with the Yakima rack, and adding this simply makes the rack useless, but I understand that it can be very useful.I will have to look into that.
So are you asking for something like a portable vent cover install of sorts here Luc, something that could be set up when it rains and taken down before hitting the road? I guess I do understand your point with the Yakima rack as a permanent set-up like the Aeroflo cover would not allow you to place larger items across your rack and would interfere.
I'm guessing a soft set-up as you described could be done with wingnuts, but if you needed to use the Yakima rack you would have to spend a few moments taking the cover back off?
Nope, I am thinking more of an accordeon type of set-up. A guess tarp material on each side and maybe a plastic piece that would extend toward the rear from the cover. A bit like a mini westfalia top tent.
But hey, I am just trowing ideas here for now. Trailer is a the cabin, snow on the ground till next may and way to many project to start working on this. But could be taking a coffe, sitting on the porch, with views over the fan cover.
@WilliamA said:
Hey all,
William A, pretty sure this is what I’m going to replace my 3-speed fantastic fan with. You can control the speed more precisely and it’s quieter at slower speeds. Saw one installed in a neighbor’s Camper and it worked great.
If you’re vent cover is resting on the body of the camper you should put some caulking around it or it might scuff you’re camper and could rub a hole in it. If the brackets hold it off the camper check it before you take it out to make sure it’s not rubbing. Seen it happen
How is your Aeroflo vent cover holding up? I am concerned about the plastic frame of the T@G fan not being sturdy enough to hold it in place while driving or in high winds. I looked at the install videos and they show screwing the brackets into a fan with a metal frame. I'd like to get a cover on mine before the summer. Thanks
My wife and I made a 4000 mile round-trip after installing the Aero Flo. We traveled from Columbia Missouri to Sugar Creek Ohio and then on to Kennebunkport Maine and down the Eastern seaboard. We then traveled from North Carolina over to Gatlinburg Tennessee. We came through the Smoky Mountains and eventually made it back to Columbia Missouri. Several times I was going as fast as 70-plus miles an hour, but usually slightly less than 65 miles an hour.The Aero Flo is just as secure as it was the day I installed it. I plan on being at uCamp 2018 and you are welcome to look it over if you are there as well. I hope this information helps.
I had 25,000 miles on my Silver Shadow with a smoke colored AeroFlo and it was still tight when I traded it in.
I now have over 30,000 miles on my T@B 320 with a white AeroFlo and it is still tight and still looks great (after I get the winter’s desert dust washed off of it when I get home!).
I purchased the Fantastic Fan cover, even though it was pricey, it is supposedly UV protected and I live in New Mexico. Also, because New Mexico is generally dry except during Monsoon season, I don't plan to need the cover a lot, Therefore, I purchased some small , heavy duty, suction cups on Amazon, and some wing nuts at Lowe's and plan to use the cover only on an as needed basis. If I lived somewhere else, I would strongly consider a permanent install but I was not excited about drilling holes in the roof considering how little I will use the cover.
The AeroFlo does not require holes in the roof. 4 holes in the flange of the roof vent, easily removable, and absolutely no holes in the roof.
Looks like Aeroflo will barely clear my garage holding the T@g Boondocks Max. Test fit today showed it would go in but the seal for ththe garage was moved. I give it a 50/50 chance once I get the bracket on. Looks like Aeroflo is one of the shortest models.
After much research and good discussion here, I have installed the Fan-Tastic Vent UB1500SM Smoke Ultra Breeze Vent Cover. I had to order the Maxxair 00-225000 Roof Vent Zero Leak Mounting Kit. I replaced the bolts for attaching the cover to the vent frame with self tapping screws. End result, works great!!
Fot those contemplating this vent, be aware that it comes in a few different models, all of which are less than the space shuttle-ready premium job. The basic model has most of the same features for $160 bucks from e-trailer.
Got the vent cover installed!@!
ours is finally done too...just in time for a Rally in Alabama
https://youtu.be/ydfKr5hWlso?t=19
https://youtu.be/Ia0huI-niz4?t=7
