Charging Station
The USB ports in the charging station are not working, but the 12V plug is fine. Is this a common issue to have? Where is a good place to start to try and fix it? How would I take it apart to check the wires? If it can't be fixed how can it be replaced? Thank you!
2017 T@G
Michigan
2020 Ford Explorer SE
The USB ports are short lived. Look for something similar on Amazon. Easy fix.
@Sharon_is_SAM said:
The USB ports are short lived. Look for something similar on Amazon. Easy fix.How does it come apart?
2017 T@G
Michigan
Here is a complete changeout description on replacing the ports.
https://teardrop-trailers.vanillacommunity.com/discussion/870/replacing-usb-ports-front-rear#latest
That is very helpful. Thank you very much!
2017 T@G
Michigan
F.Y.I.
The plugs that I used have not had any issues and when switched off do not draw any power.
Good luck.
I was able to replace the unit without any issues! Thanks for the assistance and the directions were great! I got the dual usb ports w/ a voltmeter and was able to pick one up with an on/off switch. Thanks for the tip!
2017 T@G
Michigan
- 192 Camping & Travel
- 71 Tips & Tricks
